FR: Offline mode
#122
I had the exact same experience as one of the previous posters-- spent an hour or two using Airtable to set up a database for a project. Useful right from the start- a simple an elegant solution to something I would have otherwise used a spreadsheet app on the laptop for. Except I was working on my iPad, which was very cool.
Then got on my flight and stared with dismay at a blank screen.
#123
How would you want to use Airtable offline?
In all of the normal ways - reading and editing existing bases, adding new bases.
Do you use Airtable alone, or with collaborators?
Alone, but possibly with a small number of collaborators in the future
How much do you need to be able to do in Airtable while offline?
Ideally everything, but editing, adding and deleting records in existing tables at a minimum
How tolerant would you be of having to resolve merge conflicts manually?
Reasonably tolerant
Would you primarily be using offline mode on desktop or mobile?
Mostly mobile for offline
#124
Hi, I too started using AirTable recently and was dismayed to learn the iPad/iPhone apps just show nothing when there’s no internet connection. I think a database app like this really needs offline mode for best use.
As a coach. Recording client meetings, in person (without reliable wi-fi) or on the phone (potentially remote, with no cell signal). Brush up on the details of previous meetings, that sort of thing.
Alone, for now
Read, edit existing records, add new records. Not so much tinkering with the database schema
For how long do you need to be able to use Airtable offline?
However long it takes. A few hours? A regular train journey I make – with incredibly patchy signal – takes three hours. I’d want to be working, using Airtable, the entire way, ideally.
Very tolerant. It’s just me. I know what’s the truth and what’s not.
Ideally both, but given the comparatively primitive iOS version, I’d settle for this being a mobile-only solution. If I knew I had to stick to iOS when working offline, that’d be ok.
I’ve read someone else’s suggestion for a sort of Offline toggle and that would work for me. If I knew I was going to be suffering wi-fi or mobile signal woes, but had work to do, I’d happily engage Offline mode, keep all my editing to the one device, and wait for the return home to switch back online and upload all my changes.
I definitely need to be able to see my bases, without an internet connection!
Thanks for listening.
#125
+1 - for use in rural India!
To view, edit, and capture new data.
With collaborators
Possible a few hours
Very tolerant but likely not a problem.
Mobile only
#126
I would also love an offline mode on Airtable, as I’m currently trying to centralize more and more personal (and not so personal) things on it :smile: !
Well, I’ve got a concrete example.
Not so long ago, one of our cats got really sick and we had to hospitalize it in 2 different vet clinics in just a few days : one near us and the other one pretty far, in a rural area, with no Wifi.
We got information there, information here and in just a few days, I accumulate a big and heavy pile of papers I needed to take everywhere and consult during interviews with many different vets. And it was a mess.
I was exhausted, anxious and couldn’t think straight so, I forgot things.
Since then, I’ve created a DB dedicated to our pets and I know can answer every precise question a vet could ask … but I need Wifi or roaming data (which I couldn’t get in the 2nd vet clinic) on my phone which was dying quickly at that time.
As I’ve got an iPad, if there was an offline mode, I could have just taken these 2 devices and travel lighter (without a messy pile of papers). It would have been a lot easier and far less stressful.
This just an example… I’ve got many personal other ones…
Alone
Consult, populate and edit bases.
A few minutes to some hours.
Very tolerant if it’s explicit : « This what added while offline (by « X » if collaborators) at that « Date + time » > « Accept / Reject / Merge ? »
Mobile
#127
Offline mode is a must-have feature to crown Airtable king.
I use Airtable to manage my personal life, which includes a tremendous amount of traveling and my business. I’m constantly working while on the move- and without offline caching, I’m not even able to access Airtable content at all. Currently, I’m having to take screenshots of the things I’m working on, work on them offline, then work again to add them back into Airtable when I do have an internet connection. This is pretty bad. Also, I can’t even count the amount of occasions I needed to access info that was only available on my Airtable that, without an internet connection, was frustratingly unaccessible.
Alone for now specifically because I can’t rely on my staff to work efficiently without offline caching. I’m willing to do spend the hours doing the extra offline workarounds but can’t force my team to do the same.
Review databases and uploaded content, add to and edit databases, drag and drop attachments that are immediately accessible locally and cloud sync when back online.
With all the traveling A LOT. But realistically, I’ll get wifi at least once a day so from a few minutes to 24hrs- though there definitely shouldn’t be a time limit! Max 1GB of caching should be enough for pretty much everyone.
Very. Although this should work like Dropbox. Latest data automatically overwrites previous data, but there’s an option somewhere to view ‘Version History’ with the ability to overwrite the current data with a previous version.
Mobile has to be the first priority but the Desktop version definitely needs it too for power users.
As a side note, I’m using the free version now but will absolutely upgrade when this functionality is built in as I can drop the other apps I’m using just to work around this offline limitation.
I love Airtable. It’s an amazing product that has completely changed the way I work for the better, but it’s lack of offline support just makes it not quite entirely practical.
Hope this is being worked on and will roll out soon. Please keep me in the loop on this.
#128
We use Airtable for out youth sports organization. Right now I use it for one team as without offline we’re in too many remote locations that don’t have a connection. Our parent organization is 60+ teams and would likely roll out a similar implementation. We often interact with partners, recruiters, college coaches, vendors, etc in remote locations. We would like to access data about players, venues, schools and other elements as they were last entered online.
With collaborators: players, coaches, parents.
Review last known state of the data and enter new data.
Odd question I think but typically no more than 24-72 hours.
This would be unlikely in our application - particularly if we could limit which tables could be edited offline. (I work in cloud/mobile/desktop software so this is a qualified estimation. Though if you’re looking for a model to follow, try github!)
We would only use offline mode for mobile
Great product by the way. I have used QuickBase extensively and find Airtable to be far more connected to other services and far more accessible for end users.
#129
I work as a film producer at a production company and travel frequently to shooting locations with various cell reception. Sometimes in the middle of corn fields and sometimes in rural landscapes with no cell reception at all. For Airtable to be a go-to no-brainer and for me to expand the usage of the product, I need to know I can access my Base anywhere in the world even if it’s just for reference/read-only with FULL data access from the Base including attachments and files. If we can’t see the data without an internet connection, the product becomes useless as soon as connectivity drops (bad location, weak internet, flights w/o wifi, 3rd world countries).
Currently alone, but hoping to expand to my assistant and other executives at the company.
Immediately need access to a read-only version of my Base. It would be wise to choose which Bases read-only offline access is needed for so the database size doesn’t grow without cause.
At a future point, it would be nice to change various cells’ information based upon project we have in development. I use Airtable to manage my submission/read list and to track my notes different writers.
for read-only - indefinitely for Base Owners or have an admin choose how long a team-member should “check-in” to ensure data isn’t stolen.
For editable Bases - whatever makes sense for Airtable. After that period of time has gone, the Base should transfer to Read-only.
I hate doing this. Whatever is frictionless.
Both are important. My heavy workload is done on a mac, but use mobile for reference all the time.
#130
An initial ability to just access the data offline in a copy of the Base that is uneditable and updated on the app manually would be irreplaceable. I use Airtable for storing Machine data, location, parts and service manuals, pictures in order to service and maintain hundreds of industrial machines all over my state. With cell phone coverage or wifi being mandatory, i am fairly tied down to taking pictures and screenshots of my Base so i can use that info offline. Offline usage could be limited to adding new records and editing current records. If there are conflicts it could just put that data in a New Record that could be manually resolved once i have internet access so the data isn’t lost, it’s just dislocated. I am using Airtable to manage all of my daily business, it is awesome.
#131
Without being able to use this app offline / standalone it’s completely useless for many usecases as mentioned. One of those being taking notes while being offline in an airplane…
Please implement at least a basic version of the offline mode. For example having a workspace in a single user mode. Or a workspace only available offline.
Since I am a software architect I am assuming that implementing such a feature in a profound basic version would not take longer than a week! But improve the whole project tremendously because it would open up a gigantic new field of possibilities with the tool!!!
#132
Yes please, I need offline access as well. I’d be willing to pay for this feature.
#133
+1 for offline mode so that this is useful for researchers on the field or out at sea. Would be nice to be able to access a local cached copy during a long flight.
#135
I was really hoping for a happy ending at the end of this thread. Alas…
Primarily on long flights. I want to look data up, do some filtering and sorting, make some comparisons. Read-only would be fine; I just want to be able to view it offline.
My personal Airtables are alone currently, but I could see adding collaborators in the future. At work, I have 3 collaborators. We don’t edit that often.
I’d be happy with Read-only access of a single tab quite honestly.
In most cases it would only be a couple hours.
Quite tolerant.
Desktop; I use my laptop for Airtable.
#136
I’m on planes and in internet-spotty subways a lot.
Both, depends on the base. Offline need is for both.
Everything, but at least reading, sorting and filtering. Then filling out or editing rows. Then creating rows and columns.
Whatever makes offline Airtable possible.
Both, but mostly mobile.
#137
We run corporate team off-sites, and many of the venues we host events at are in the mountains with no cell service. I would want to run through programming and inventory while onsite to make sure we are set up. As it is, I am exporting each table to a csv, importing it to google docs and enabling offline mode.
Write is mostly alone, but read w/ collaborators. Would love cheaper “read-only” collaborators too.
Read-only access is probably sufficient for my purposes.
If read only, not a problem right?
Mobile.
#138
Want it for mobile write and edit to create /edit new tasks and projects and thoughts and deciision journaling as I use it for my central repository for all these things. And as such it needs to be available at all times when I have inspiration or a thought comes to me regardless of whether I have service (on a plane, in the countryside). I personally don’t use collaboration at all for this as it is inherently private.
#139
How is this not a thing still Airtable?
I think the Community has spoken this is a needed feature.
PLEASE :pray:
#140
Yes an offline mode would be most useful. I am often in remote places and need to check my entries. Wouldn’t need to edit as much as read.
#141
I travel often, so on planes, in places with no signal and worksites that don’t offer wifi.
Mostly alone, but occasionally with collaborators.
At least reading and creating new records. Updating records would be perfect. Why not do that, make it so you can’t change structure while offline?
If it means I get to work with Airtable offline, absolutely. Let’s do it.
Tablet, then phone, then desktop.
#142
In areas of patchy internet connectivity, esp. when making site visits.
With collaborators.
Simply being able to view read-only version would be great.
N/A - only need read-only.
Desktop.
