Gantt Lineal - project with different beginnings
Topic Labels: Dates & Timezones
611 1
IEA_Escobar
Good morning, I’m trying to create a gantt chart in which I can represent a proyect with different beginnings and ends. But instead of appearing below, continues in another start date on the same line, as it shows in the following picture:
airtable gantt1
The project 26324402 (orange (?)) I modified it in paint to explain my idea.
I thank you a lot
Welcome to the community, @IEA_Escobar! :grinning_face_with_big_eyes: Each line in the Gantt chart represents a single Airtable record. Because of that, it’s not possible for a record to appear more than once on the same line. To have a given project repeat in different ranges of time, each instance will need to be a separate record, and will appear as a separate line in the chart.
