Generating tasks for a project from a table with multiple templates (script)
900 2
Jon_Schober
Hi Airtable community!
I have a base structure where:
  • The first table is a list of email projects linked to a second table of tasks
  • The second table contains all the tasks for the email projects in the first table, grouped into “send” dates
  • A third table with a template of email tasks that are the same for each email project
I’ve implemented a script so I can generate the email template tasks with the click of a button within the first projects table:
let projectsT = base.getTable('Marketing Projects');
let tasksT = base.getTable('Project & Individual Tasks');
let taskTemplateT = base.getTable('Email Task Template');
let project = await input.recordAsync('Pick a project', projectsT);
if (project) {
    output.text(`You picked ${project.getCellValueAsString('Name')}`);
    output.text(`Creating tasks for ${project.getCellValueAsString('Name')} ... please wait`);
    let taskTemplateQ = await taskTemplateT.selectRecordsAsync();
    let projectTasks = [];
    for (let task of taskTemplateQ.records) {
        projectTasks.push(
                fields: {
                    'Name': task.name,
                    'Retention Channel': { name: 'Email'},
                    'Task Status': { name: 'Not Started'},
                    'Project': [ {id: project.id} ]
    await tasksT.createRecordsAsync(projectTasks);
    output.text('Tasks created!')
I’m having trouble creating another template within that third table that I can choose from when going to generate tasks via the button I have in the first table. I can’t seem to figure it out with any documentation I’ve read; is there a way to incorporate a dropdown upon running the script so that I can choose which template to trigger?
I don’t think so I’m afraid
From what I can tell, your third table has like, different sets of email tasks, so email task 1, 2, 3 belong to Set A, email task 4, 5, and 6 belong to Set B?
If so I think I would end up creating a Task Template table where the records were Set A and Set B etc, and link the email tasks to those
I would then use another input.recordAsync to select the task template I needed, grab the records that are linked to the task template, and then create the records from there
As a general aside, I would highly recommend considering this comment by kuovonne about keeping the templates in the same tables as the actual data as it’s proved super helpful for my circumstances
Not a dropdown per se, but you could use input.buttonsAsync to display a series of buttons to the user. The button they click on would correspond to a email template that they wish to use.
