Help adding color to field forumla
I have the formula below to give us a due date for items, BUT when the item is due I would like to add an emoji OR change the field highlight color. Can anyone help me figure out what I need to add to this formula in order to make this happen??
DATEADD({2-Step TB},11,‘month’)
Individual fields can’t be colored. If your base is in a Pro level workspace (or greater), you can use record coloring, which adds a colored marker to the left edge of the record (in a grid view). This can be set to use a condition similar to filtering, so you can color the record if that date field matches today’s date.
Adding an emoji is definitely an option, but I wouldn’t recommend doing it in the same field. Right now your calculation is outputting a date. To add more text (including emoji) to that same field with the date, and have that text based on the date, will require a much uglier formula, in part because you’re calculating the same date in multiple places. I’m all about keeping things clean and eliminating duplicated calculations if possible, so I suggest using two fields: your current one to calculate the due date (I’ll use {Due Date} for the field name), and another to add the emoji.
Screen Shot 2019-12-07 at 3.08.22 PM
The formula I’m using for {Date + Emoji} is:
IF(IS_SAME({Due Date}, TODAY()), "⚠️ ") & DATETIME_FORMAT({Due Date}, "L")
In the end, you’d hide your current field and just leave the one with the optional emoji visible.
Thank you for your response :slight_smile:
I have a screen shot to show you what I tried based on your feedback…
And here is my formula:
IF(IS_SAME({2-Step TB EXP}, TODAY()), “:x:”) & DATETIME_FORMAT({2-Step TB EXP}, “L”)
It will allow me to “save” it, but the emoji doesn’t show upon the 4/30/19 one when it should? Can you see what I am doing wrong?
Ugh, it keeps telling me i can’t put images in my post… So I cannot attach the screen shot… :confused:
That emoji will only appear if the date in {2-Step TB EXP} matches today, and today isn’t 4/30/2019.
New users are restricted from doing certain things, including adding images. Once you’ve been active on the forum for a while, it will begin removing those restrictions.
