Help Correcting Nested IFAND Statement
After searching here and looking at the nested ifs reference, I believe I’m close, but not quite there.
I want the formula to look at values in two fields (likelihood of a problem; severity of a problem) and return a third value (combined level) depending on the combination. A sample of part of it is below.
Example formula so far:
AND({Likelihood} = “Improbable”, AND({Severity} = “Acceptable”)),
“Low”,
AND({Likelihood} = “Improbable”, AND({Severity} = “Tolerable”)),
“Medium”,
AND({Likelihood} = “Improbable”, AND({Severity} = “Undesirable”)),
“Medium”,
AND({Likelihood} = “Improbable”, AND({Severity} = “Intolerable”)),
“High”
Instead of
AND({Likelihood} = "Improbable", AND({Severity} = "Acceptable"))
do this:
AND({Likelihood} = "Improbable", {Severity} = "Acceptable")
Or simplify your formula to only ask each “question” once:
   SWITCH(
      {Severity},
      "Acceptable", "Low",
      "Tolerable", "Medium",
      "Undesirable", "Medium",
      "Intolerable", "High"
Thank you! I appreciate your kindness here.
