Hey @Summer_Barney! Welcome in!
As a note, I work best when I can solve something myself, so I created a base where I built this out.
If you’d like to look at the example base I used below, here is a viewing link to the base.
Additionally, you can open up that shared view, then use the button in the upper right-hand corner to copy the base yourself and really poke around.
So, here’s the story I’m understanding from your post:
In Airtable, I have five eggs.
Now, I want to make a cake, so I go into Airtable and look at my recipe record.
But I need eight eggs to make a cake.
Because of this, Airtable has marked my Can I Make It? field as No
Now, when I have eight OR more eggs, Airtable should change the status to Yes
(I know that your requirement here is based on whether or not any of the ingredients has an inventory of 0, but that’s just how I thought about it!)
If that is correct, then here’s how you do it!
I created two tables, one for recipes and the other for ingredients.
Next, I created a rollup field in the recipes that looks for the minimum quantity of any of the ingredients.
The Automation
Now, I decided to use the “When a record is updated” action, this will allow us to update the select field to either Yes or No based on your inventory.
Here, we are watching for updates to the Lowest Quantity rollup field.
The first condition action evaluates if the lowest quantity is 0.
If this is true, then update the select field to ‘No’.
Now, this is where you ran into issues.
In automations, it will not provide you with a list of values to pick from.
Instead, you have to type the string (value) that you want to appear.
If the value you type in does not already exist in the options, it will create a new one
This is why you couldn’t find the options to choose from.
So for both actions, you want to actually type it into the update, instead of using the input dialog that was confusing you.
You can see here that even though I just typed in the option, Airtable found that I already have an option for No, and then just updated it using what already existed.
To finish up, for the next conditional action I just evaluate if the quantity is equal to or greater than 1, and if that evaluates true, then I update the field by typing in Yes.
Let me know if you have any questions or if I just completely misunderstood something.
