Help. DateAdd is adding 5 hours instead of minutes
1048 4
Traci_Levine
I have created this formula that will set the duration when something is selected:
SWITCH(
{Select},
‘Code Review’, 1200,
‘Design Review’, 1200,
‘Resume Review’, 1200,
‘Career Coaching’, 1800,
‘Team Coaching - Design’, 3600, ‘Team Coaching - Code’, 3600, 1200
It is then connected to another formula field to create and End Time:
DATEADD({Time}, {Duration}, ‘seconds’)
However, the time I get returned is 5 hours later not the minutes I have added. Anyone have a suggestions.
18 - Pluto
18 - Pluto
Something tells me this is a timezone issue. What’s the timezone setting on your {Time} field?
4 Replies 4
Can you post screen captures of both your record values and the configuration of your duration field?
Could your duration field be set to show h:mm but you are using it as h:mm:ss?
Screen Shot 2021-05-07 at 10.04.19 AM Screen Shot 2021-05-07 at 10.04.38 AM Screen Shot 2021-05-07 at 10.04.52 AM Screen Shot 2021-05-07 at 10.04.57 AM
18 - Pluto
18 - Pluto
Thank you for the screen captures. That make things much more clear and showed that it was a time zone issue.
I thought this meant that the duration should have been 5 minutes, but the formula was adding 5 hours instead.
Instead, the result was adding the minutes you wanted plus an additional 5 hours, due to the time zone.
