Help for building RPG support
Topic Labels: Views
1159 0
Dwayne_Hendrick
Here is the idea that I have: knitting together multiple groups running the same RPG. What I want to create is a database that will show the status of various cities in a region based on what date it is. Perhaps the tavern in Rivendale burns down on March 1st. I want groups that visit Rivendale in Feb to see that the tavern exists but anyone visiting after March 1st will see that the tavern is gone.
I was thinking of being able to utilize the calendar view so a group would click on a date and then see the records for each town and its status for that date.
Any ideas or suggestions?
0 Replies 0
