Help me add a date condition to a nested IF formula
1620 6
Beth_D
Hi there. I’m having trouble creating a nested IF formula with a date parameter.
I use airtable to calculate invoice totals for my business, and we have been offering a 10% discount on orders of 4 or more items. I use a field with this function:
IF(Quantity1+Quantity2+Quantity3+Quantity4+Quantity5 > 3, “------>”, “NO”)
and a BILLING TOTAL formula field outputs different numbers based on the response.
The problem I’m having now is that we’ve increased the threshold to 6 items before we offer the discount. I would like to create a nested IF formula that can take into account the date a deal is closed. I don’t want to change the formula to > 5, because then it will calculate our past deals inaccurately.
How can I add a condition that will apply the discount if > 3 only if {Date closed} is before 6/24/18, and > 5 if {Date closed} is either blank or after 6/24/18?
I know this is super specific to my database, but I hope someone can help me! Thanks in advance!
6 Replies 6
I think this should do it:
  OR(
    AND(
      IS_BEFORE(
        {Date closed},
        '6/24/2018'
      Quantity1+Quantity2+Quantity3+Quantity4+Quantity5>3
    AND(
      OR(
        {Date closed} = BLANK(),
        IS_AFTER(
          {Date closed},
          '6/24/2018'
      Quantity1+Quantity2+Quantity3+Quantity4+Quantity5>5
  "NO"
Hmm. That’s seems like the right direction, but unfortunately it returns #ERROR!
Is it giving you #ERROR! in all situations?
I just tried it and I only get #ERROR! if {Date Closed} is blank:
I can work on that, but if you are getting #ERROR! in other situations as well, there may be something else going on in your base that I am not aware of…?
Beth_D
You’re right, it only shows an error on deals with no {Date closed}. I’d appreciate your help with this last issue, too. Thanks!!
Ok, had to rearrange a bit to get the BLANK error to go away - use this:
    Quantity1+Quantity2+Quantity3+Quantity4+Quantity5>5,
    "NO"
    IS_AFTER(
      {Date closed},
      '6/23/2018'
      "NO"
      Quantity1+Quantity2+Quantity3+Quantity4+Quantity5>3,
      "NO"
NOTE: I changed the IS_AFTER date to 6/23/2018 so that 6/24 is included in the new >5 requirement.
YES! Jeremy, you’re my hero. I’m pretty proud of the database I’ve designed, but occasionally I’m reminded just how little I actually know, haha. Thanks again!
