See unfortunately, the issue isn’t as simple as being able to put it all on one table. We currently have 250+ columns that way. And we can’t all work in the same base. Each sub-department can’t have access to all of the information, only the records within their sub-department. And we need dates for the actions, statuses of the actions, and such so we can’t just use checkboxes.
Ideally we’d have
A base per sub-department, with one main base where records and info could be distributed from. But we also need the sub-department to make any changes it needs as well.
Essentially the Department Base needs to record all records and changes made to those records. Even if changes are made in a sub-department base.
I Department Base
I I_ Demographics
I I_ Actions
I I_ Licensing
I_ SD-1
I I_ Demographics
I I_ Actions
I I_ Licensing
I_ SD-2
I I_ Demographics
I I_ Actions
I I_ Licensing
I_ SD-3
I I_ Demographics
I I_ Actions
I I_ Licensing
I_ SD-4
I I_ Demographics
I I_ Actions
I I_ Licensing
I_ SD-5
I I_ Demographics
I I_ Actions
I I_ Licensing
I_ SD-6
I I_ Demographics
I I_ Actions
I I_ Licensing
