HELP! Too many records in one base, need to upgrade
490 2
Mathieu_Cressy
HELP!!! We can’t use zapier on our base in airtable because they say we have too many records. I have contacted you several times with no answer, we need to be able to have more records on certain of our bases. Please answer!!!
Thanks in advance.
Best regards,
Mathieu Cressy
Are you unable to upgrade your bases yourself?
We can’t upgrade ourselves as it is to upgrade towards the “enterprise” plan.
The only thing we can do is to contact the sales team, but we have not been able to reach them…
