Help with airtable and api explorer intuiface
Topic Labels: Sync
476 0
On_Point_Liverp
Hi Guys i am trying to show my records of my table on INTUIFACE which i can do with list records, but i need to be able to edit the records live. when i try update record it only shows 2 records not all and when i update a cell it updates them all even if PATCH is used, i delete data from the cell in intuiface so it doesnt change it and it deletes the data also. how do i show a list of all records and be able to edit them and selec each record and its fields to edit like normal
0 Replies 0
