Help with DATETIME_DIFF Formula
1030 7
Peta_Howlett
Hi team,
I’m hoping for some help. I am trying to work out the number of weeks between 2 dates. It keeps returning the results Nan and I have no idea what I am doing wrong. Here is the formula I am using.
I want to know how many weeks between “Cancel Date” and “Sale Date”. If anyone could give some input or advise it would be massively appreciated. Thanks
DATETIME_DIFF(
{Cancel Date},
{Sale Date (from Sales)},
‘weeks’
7 Replies 7
Hey Peta, hmm that looks right. Could you provide a screenshot of the relevant tables / fields so that I could troubleshoot it perhaps?
In the meantime, I’ve set something up here for you that you can use to compare against your own base
Screenshot 2022-07-19 at 12.54.27 PM
Screenshot 2022-07-19 at 12.54.25 PM
Peta_Howlett
Thanks so much for your help Adam. Here are 2 screen shots
Screen Shot 2022-07-19 at 2.24.39 pm
Screen Shot 2022-07-19 at 2.24.29 pm
Hey Peta, it looks like the Cancel Date field is a Single Line Text field; could you try changing it into a Date field?
Peta_Howlett
OMG you are my hero!!! It works!!! thank you so much!!! I really really appreciate your help. Thank you!
Anita_Pangestan
@Adam_TheTimeSavingCo Hi Adam, could you also check my formula? I’m having the same problem as @Peta_Howlett but both fields, in my case, are already in Date format.
Screen Shot 2022-07-20 at 17.05.24
Screen Shot 2022-07-20 at 17.05.33
Hi Anita, your problem’s probably to do with the formatting of the Duration field I reckon
Screenshot 2022-07-20 at 6.23.40 PM
Try setting it to Integer instead of Duration
Anita_Pangestan
Thanks so much for your help. It worked!
