I’ve attempted to follow the recommendations here to detect duplicates in a field but have not been successful and could use some expert eyes on what I’ve implemented. I did put a reply on that thread but since it’s a couple of years old, figured I should start my own question. Here are 2 screenshots from the 2 tables in play. Anyone see where I went wrong? TIA!
values
is a pure array, the formula you wrote needs to handle strings. So replace all instances of values
with ARRAYJOIN(values)
Thanks for the reply @Kamille_Parks
I thought the field {All IDs}
being an ARRAYJOIN
already would then be put into the Number of IDs
rollup as the long text result of the ARRAYJOIN
You’re doing a rollup of a rollup. So you’re still dealing with an array of strings, even though every record is linked to just one record its still an array.
Thank you for the explanation and this worked great!
