Help with moving data based on matching text
484 0
Mark_Doe
Hi all,
New to airtable so need a little bit of advice.
I have set up a form on my website to collect data and sent it back to airtable.
Issue I am having is that I am trying to work out how to move data based in a row to another record with matching text.
So for example if I had a student enquiring about ‘Science for Beginners’ and another for ‘Advanced Maths’ I would like to add them to the relevant sheet under that course group.
Is this possible to set up automatically with zapier etc?
Look forward to hearing from you.
Regards,
Mark
0 Replies 0
