Hi everyone, Can someone help me with formula Regex_extract. In Airtable I have a field with text in quotes: " “msg”: “2. Have a second version of that same photo with no background”" .
I can’t get rid of the quotes with formula REGEX_EXTRACT.
Do you just want to remove the quotes?
You could do that with the SUBSTITUTE() function:
SUBSTITUTE({Field Name}, "\"", "")
Scott nailed it. That aside, it appears that you’re misunderstanding the purpose of REGEX_EXTRACT()
. It’s not designed to selectively remove text from a string and give you what’s left. That what SUBSTITUTE()
and REGEX_REPLACE()
do. REGEX_EXTRACT()
is designed to find text matching a pattern and extract the first such match.
