Help with Script
1205 3
Michael_Andrew
7 - App Architect
7 - App Architect
I am trying to add all records from a view in a separate table to a field for all records in a view on another table.
let TBTable = base.getTable(‘Technical Comments for VB’);
let TBView = TBTable.getView(“Shared to All Trigger”)
let TBQuery = await TBView.selectRecordsAsync();
let TBRecord = TBQuery.records;
let VBTable = base.getTable(‘Verifier / Trainer Body’);
let VBView = VBTable.getView(“Verifier Bodies (Public List)”)
let VBQuery = await VBView.selectRecordsAsync();
let VBRecords = VBQuery.records;
let d =
VBRecords.forEach(c => d.push({id: c.id}));
await TBTable.updateRecordAsync(TBRecord.id,{‘Verifier Body’: d});
output.markdown(’# Done :rocket: ’)
I am getting an error that the record is not defined. Can someone help?
Thanks,
its a replacement for your current line with updateRecordAsync.
3 Replies 3
Your problem is you’ve passed TBRecord.id, but TBRecord does not have a property of id. As you’ve defined it, TBRecord is an array of records which looks something like this:
    {id: xxx1, name: "Record 1"},
    {id: xxx2, name: "Record 2"},
    {id: xxx3, name: "Record 3"}
You’ll need to loop through each item in that array, similar to how you’ve done with VBRecords, like this:
TBRecord.forEach(x => {
    TBTable.updateRecordAsync(x.id, {'Verifier Body': d})
Thanks. Sorry where does that part go in the script. I apologize I’m very new to coding.
