Hi community members, I need help with integrations, automations, and setting-up bases
Topic Labels: Automations
641 4
Dominick_Davis
Hi, I am looking for someone to help with integrating, and automation.
4 Replies 4
Welcome to the community, @Dominick_Davis! :grinning_face_with_big_eyes: That’s a pretty broad description. Could you please share more details about your use case and what specifically you want to accomplish?
Dominick_Davis
Hi Justin,
Thank you, I need to create some zap automations, and help with my existing system. I have been using Airtable for 2 years now could really use assistance from someone skilled in this system.
You could also post over in the #developers:work-offered category. I recommend going even deeper into your use-case description if you choose to post there. The more details you can share about what you hope to achieve, the easier it will be to find a consultant who’s a good fit.
