How can I create a graph to track my current finances (i.e. bank balance) towards a goal (monthly and/or yearly)?
Topic Labels: Extensions
1042 5
Torus_Global
Hi, I’m guessing the “charts” app would be the way to do this, but I could be wrong…
How do I create a chart/graph that tracks my current finances (i.e. bank balance) towards a goal (monthly and/or yearly)?
For example…
I input expenses/income every day into respective views on AT and those numbers feed into a “totals” view…
From this totals view, I’d like to have goals set up (and the chart) so I can see if I’m on track to reach a set goal for that month…
Any assistance would be greatly appreciated. Thanks in advance. -Christopher
5 Replies 5
Torus_Global
@Andrew_Wright - would you happen to know how to do this?
Andrew_Wright
@Torus_Global I’ll check it out today. Busy day at work today
Andrew_Wright
@Torus_Global Ok, I’m looking into this. The closest I am right now is a percent of your goal as a field. This is a tough one.
Hey @Andrew_Wright - quick follow-up to see if you ever managed to find a solution/workaround for this? Thanks!
Felix_Fabich
Generally speaking, the Vega-Lite block can do that.
The Vega-Lite block might not use the lastest Vega-Lite version though. So there are some limitations.
