How do i add more records in Linked Field using Pabbly connect?
Topic Labels: Automations
346 0
kennypurnomo
7 - App Architect
7 - App Architect
Pabbly connect is a platform that works like Zapier. It can create new record, update record or delete record.
I have a record which has a linked field i want to update. I cannot “Add” records in this field using Pabbly but instead i always replace the old record and substitute it with the the record.
Any idea?
Thanks
0 Replies 0
