How do you cancel or undo edits you've made to an automation?
Topic Labels: Automations
1329 2
Colleen_Brady
When working with automations, how does one cancel edits? What if I don’t want to update an automation because I made a mistake?
And when the pop-up asking about changes appears, is there a way to cancel and not apply updates?
DontUpdateAutomation
Thank you!
Pulpo_Ludo
Have you found a solution to this problem?
The interface can be buggy, depending on the browser and local cache peculiarities. Refrshing the page usually works on my end if the UI gets stuck (usually after entering and exiting the edit script view in quick succession).
