How much maximum data can Airtable handle?
6425 2
glakum_sc
How many rows/columns/cells can Airtable handle at its maximum limit? For example, Google Sheets can handle up to 10 million records. What’s the limit for the Airtable?
You can have a maximum of 500 fields/columns per table. The maximum number of records/rows depends on your plan—pro plans are limited to 50,000 records per base, this a maximum of 50,000 in one table.
However, as you approach these limits you may find that your base slows down.
If you need millions of rows of data, Airtable may not be the right platform for you.
@kuovonne Thanks for your thoughts on this. It would help us decide on the database stuff.
