How to add multi options (>100 options) to multiple select questions?
672 2
Mint_V
I have tried to add 100 options to multiple select questions in Air table Form.
Is there any tips in how to do it quickly?
18 - Pluto
18 - Pluto
Hi Mint, if I were you I’d have each option as a single value in the field and then convert said field into a multiple select
convert to multiple select
18 - Pluto
18 - Pluto
Thank you.
I made it happen! feel like magic!
