How to Average Rating with Stars Instead of Numbers
4867 1
Reuben
Hi, I have a formula that averages 2 ratings fields. I wish the formula field would show stars instead of numbers. Is there a way to do this with the rating field? Or with a more complex formula? See my current screenshot below.
Hi @Reuben - have a look at this post, which is a workaround for turning an integer into a star:
You’d probably also want to do a ROUND() on the average formula to make sure you get an integer number of stars.
JB
