How to clear a multiple select field using an automation
521 1
Ashley_Tarbet_1
Hello!
I’m trying to run an automation that clears a multiple select field rather than appending it. The only help topics I can find are about adding a value not clearing a value. Does anyone have a suggestion on what to do? I have tried everything!
Thanks :slightly_smiling_face:
hi.
try space. if it’s scripting step, put empty array there, []
