How to configure a conditional, combined DATETIME_DIFF formula
1587 2
Aysia_Saylor
What would be the easiest way to configure a formula that combines all of these?
  • IF({Request Type}=‘New’, DATETIME_DIFF({DCML Issue Date Lookup},RequestDate,‘days’)
  • IF({Request Type}=‘Major Update (Procedure Change)’, DATETIME_DIFF({DCML Rev Date Lookup},RequestDate,‘days’)
  • IF({Request Type}=‘Minor Update (Formatting, Spelling, Grammar, etc.)’,DATETIME_DIFF({DCML NCC Date},RequestDate,‘days’)
  • IF({Status}=‘Incomplete / Closed’, DATETIME_DIFF({Status Last Modified Date},RequestDate,‘days’)
I tried a formula that combined the first two, and the system accepts it, but it doesn’t return anything.
Thanks :slightly_smiling_face:
Kamille_Parks
16 - Uranus
16 - Uranus
I would use a combination of SWITCH() and IF() statements for this:
SWITCH(
   {Request Type},
   "New", IF(
      AND({DCML Issue Date Lookup}, {RequestDate}),
      DATETIME_DIFF({DCML Issue Date Lookup}, {RequestDate}, "days")
   "Major Update (Procedure Change)", IF(
      AND({DCML Rev Date Lookup}, {RequestDate}),
      DATETIME_DIFF({DCML Rev Date Lookup}, {RequestDate}, "days")
   "Minor Update (Formatting, Spelling, Grammar, etc.)", IF(
      AND({DCML NCC Date}, {RequestDate}),
      DATETIME_DIFF({DCML NCC Date}, {RequestDate}, "days")
   "Incomplete / Closed", IF(
      AND({Status Last Modified Date}, {RequestDate}),
      DATETIME_DIFF({Status Last Modified Date}, {RequestDate}, "days")
The above formula will test the {Request Type} and depending on its value output the relevant difference between two dates only if both those date fields have a value.
Kamille_Parks
16 - Uranus
16 - Uranus
SWITCH(
   {Request Type},
   "New", IF(
This is great, thank you!
