How to create buttons that will filter an elaborate table
1163 1
Mike_Farnan
I have a base with many tables. I’d like the interface to be buttons that if one clicks on a button a filtered list (in kanban form) will display. Can this be done within Airtable?
Welcome to the community, @Mike_Farnan! :grinning_face_with_big_eyes: The only way this will work is if you make each of the desired Kanban views in advance. Airtable cannot make (or modify) views on the fly. That part aside, you could create a series of records in a dedicated table, with each record containing the URL for a specific Kanban view saved into a {URL} field. Use a button field with the “Open URL” option to pull the URL, and you’ve got buttons that will open specific views.
