How to create checklists for a task? Zapier?
#1
Many of my tasks have a bunch of quick jobs to tick off. They’re not worthy of being a separate task. So far I’ve resorted to just writing them down in the notes cell as a sort of bulleted list. Is there a way to turn them into a proper checklist?
Perhaps zapier or some other work around?
#2
Create a table for the quick jobs and link them to your table of tasks.
On the quick jobs table my a check field so you can mark something as done
You can see an example with Airtable’s "Project Tracker"
