Hello everyone, everything good? I’m facing a difficulty in extracting data from the airtable to the power bi free version, even using the api the power bi doesn’t do the extraction, can someone help me?
Hey @Vitor_Donato,
You can check out the options in this post →
If you can’t use the API connector, then you can use a tool we helped build - Sync Inc - so connect your data to PowerBI using a Postgres database.
