I’m trying to import accounting from a CSV file in Airtable.
In the CSV file the number is formatted like this :
3240,50 (European format - Three thousand two hundred forty Euro and fifty Cents)
When i import in Airtable it become :
324,050.00 (US format)
(It can change depending on how i set up the decimal on the field)
The result is a wrong number so i can’t use it as it is.
I’m quite new on Airtable so i hope to find a quick fix.
Any help would be very appreciated.
Thanks
