How to Format Currency when doing Text Concatenation?
5969 4
Alberto_De_Lucc
I have a Formula field where I concatenate text from a Price field to create a currency string (text) for further copy and paste purposes.
When I concatenate the Price field, I get the floating number instead of the formatted price.
Price field formatting: $ 18,322,511.53
Formula field string I get: 18322511.5264
Now, I know I can concatenate the “$” symbol. However, I don’t know how to format the number itself to allow for commas and decimals.
Do you know how?
—Alberto
4 Replies 4
Take a look at the formula definition for the {DatePrice} field in this demo base. It should give you the basic structure you can adapt for your own purpose…
@W_Vann_Hall Thank you for your reply! Indeed, I noted a construct I hadn’t seen documented anywhere. How to use &"" to coerce a value into a string. The rest was dealing with LEN and REPLACE and similar. My solution doesn’t work for every edge case, but it was good enough.
As this topic recently received a thumbs-up, I felt I should note a much more comprehensive approach to the question of formatting text representation of currency and number values can be found here. (@acdye, this means you! :winking_face: )
acdye
Appreciate you! I’ve actually officially started a workspace just for references. So far it’s just some bases of yours. Thank you for sharing your Airtable knowledge with the community.
