How to Group Multi-Select or Linked Record differently?
5499 2
Hannah_Wiginton
10 - Mercury
10 - Mercury
How do I Group the multi-select field or the Linked filed to where it will show only one option vs Grouping the 2 or 3 I have in the original record?
I am tracking my Daughters Daily Symptoms, mood, meds, etc.
Here I am grouping the Symptoms. How do I only show the 1 Symptom vs showing all 3 from that day? Maybe I have this setup wrong for what I’m trying to do.
Any thoughts?
Thank you!
______________________________________
Hannah - On2Air.com - Automated Backups for Airtable
Hi Hanna!
I would use an auxiliary table, what has extra advantages: https://support.airtable.com/hc/en-us/articles/218734758-A-beginner-s-guide-to-many-to-many-relation.... Then you could Group in that extra table by the singular Symptom.
You could also extract the first Symptom with a Formula field and something like this: Split First and Last Names
Hope that helps 🤷
Thanks Elias for commenting! I created the Symptoms as Linked Records and created a table for it. I guess then just grouping by name. That’s a lot of tables to look at to Group what I’m wanting, but I believe that’s what I want.
I’ll have to read more about the Formula field and extracting the Symptom.
Thanks again for the help! :slightly_smiling_face:
