How to Handle Audio Notes?
1213 0
Garland_Coulson
I have started delegating a lot by video which works fantastic. I just create a field in Airtable called something like “Video Instructions” and then create the video using the Loom extension and drop the link into it.
Is there a similar way to do audio? Sadly, Loom doesn’t do audio only at this point.
How are you all handling audio notes in Airtable?
0 Replies 0
