How to lookup fields from a pivot block
Topic Labels: Extensions
870 0
Frances_Rebolli
I want to know if there is a way we can treat a pivot block as a table, so that I can link Table A to this pivot block. Then in Table A, I would like to have a lookup column where it can pull in data from fields within the pivot block.
Any advise would be greatly appreciated :slightly_smiling_face:
0 Replies 0
