How to make calculations in two tables using currency fields
842 2
Anna_Doehner-Do
I’m brand new to Airtable and getting to grips with it all so forgive me if this is a simple and stupid question.
I’ve got a table logging expenses by two people. I’m using a currency field to add the amounts spent by each person.
Now I want a second table that shows the overall funds both people start out with and then a field that shows the current funds available which updates according to the expenses logged in the expenses table.
Can someone explain to me how to do that? I don’t even know what sort of keywords to look for in the help sections.
Thank you so much for any help!
Anna
Assuming each record in your Expenses table is linked to a table for People, the People table could include a Rollup-type field to add up all the values from your currency field for the records linked to each particular person using SUM(values).
If your People table has a “starting value” currency field, you could use a formula field to subtract all the expenses from the starting value: {Starting value field name} - {Expenses rollup field name}
Thank you!! This is exactly what I needed. I could not figure this out on my own.
