How to merge 3K records in 5 bases into one base ? ( Easiest way )
432 1
Jay_P
7 - App Architect
7 - App Architect
How to merge 3K records in 5 bases into one base? ( Easiest way )
Based on your post here it sounds like you figured this out for yourself.
