Is it possible to move (reorder) columns in grid view? I can’t seem to move them at all.
You can’t move the first column (which is the primary field), but you can move the other columns. Just drag-and-drop the column headers.
Scott, I do appreciate your taking the time to answer such a simple question however I have tried several times to move the adjacent fields to both right or left and it appears they are able to be moved but when I let go of the cursor the field snaps back to its original position.
Is there some kind of lock?
Thanks in advace.
Yes, a view can be locked — but your screenshot shows that your view is unlocked. Make sure that you’re dragging the column far enough to move positions.
Oh well, I better stop before I kick the cat. I’ve tried moving all the way over to the last column. No luck. I click the title of the field say the “Date Recorded” hold the left mouse button down, drag all the way to the right. The cursor turns into a hand and the entire column grays out as I move it to the right. I it all the way t o the right and let go of left mouse button and the “Date Recorded” field just snaps back and stays where it is.
I must be having a brain freeze or something. It must be something real simple.
Not sure. This is basic functionality that is built into Airtable. It sounds like the problem is on your side — maybe try a different web browser.
You can also try re-ordering columns by using the drag handles in the “Hide fields/hidden fields” control.
If that doesn’t work, I recommend standard troubleshooting procedures: trying to move columns in a different table/base, closing & restarting Airtable, restarting the computer, contacting customer support, etc.
I think it’s a browser issue as I’m able to move columns on my IPad but not Chrome.
This topic was automatically closed 15 days after the last reply. New replies are no longer allowed.
