How to number questions in a Form?
Topic Labels: Views
920 3
Dena_Mendelsohn
I have a form with a lot of questions, which I’m sharing with people as a questionnaire. Is there a way to have the questions numbered? My questionnaire looks good otherwise, but I’d really like to have each question numbered. I hope there’s a way to do this. Thanks in advance!
3 Replies 3
Yes, you can change the field labels on your form to whatever you want. You can’t autonumber them, but you can just manually add numbers yourself.
Thanks! How do I do that? Or am I literally writing the number before the first word in the question?
Yes, you are literally writing the number.
