Is there an easier way to move a table from the end of a base (right side) to the front of the base (left side) without having to click & drag?
Thank you!
Thank you!
I think I just found the answer myself. You can click on the hamburger menu in the upper left of the base to display a search field to find a table. Here you can see all your tables on a scrolling list and can “grab” any of them by clicking on the “handle” provided to the right of each table label and drag it to wherever.
Sorry for such a basic question. I’m a newbie.
No worries. We have all been newbies at one point. Thank you for coming back and posting the solution. It will help other future newbies out there.
