Is there any way to allow only some fields to be editable in a view ? Through sync’ed bases / views / anything?
Regards,
Ruchika
Regards,
Ruchika
Hi @ScottWorld thanks for the tip!
This looks good… So, this would mean that either I set permissions for individual collaborators or I set permissions for the role of eg. Editor.
So if I have 10 collaborators with Editor privilege, 5 of them should be able to edit only field “A”, other 5 only field “B”. Looks like the only way to do this is by setting individual collaborators (by selecting their names) on the field permissions.
Or else I give all 10 access to A & B fields both by selecting Editor in permissions.
Am I on the right track?
Regards
