How to submit a airtable form by using parameters in URL
1059 2
Joris_Even_JE_O
Hi Airtable friends,
I am trying to prefill a form using parameters and then submit the form trough parameters in one URL.
I am using the form prefill parameters to prefill the form like this. That works (?prefill_Form+example=blabla)
Is there a Parameter for Submit?
What I am trying to accomplish
This will be used in a newsletter. The parameters will tell us who clicked the URL and populate airtable + send a e-mail using zapier.
If there is a good alternative for this, that would be great aswell. :slightly_smiling_face:
Unfortunately not.
I would recommend using external form software like JotForm for this.
That’s what most of my clients are using, although there are dozens of competing form building apps out there.
Ok, thanks for the reply!
