How to use CSS selector on frame content?
Topic Labels: Extensions
2601 5
Stephen_S
I can successfully clip content on some pages but not others. The defining difference seems to be that content in a frame can’t be clipped. Is there a way around this or a different syntax that needs to be used (for example, if wanting to clip an element with a particular ID in a frame)?
Thanks.
5 Replies 5
Andrew_Wingrave
Hey Stephen, would you mind sharing an example of what you’re trying to do, so I can help here?
Sure. So, for example, on any grants.gov announcement page (such as this one), I would like to be able to select the name of the grant opportunity. In this case, it’s BAA-OAA-LLDI-2019-ADDENDUM01. I used Chrome’s Inspect tool to find that it has an ID of “oppNumHeading”. (Hopefully this is clear from the screenshot I’ve attached.)
However, if I put #oppNumHeading in the CSS selector field for the clip action I’m trying to create, nothing happens.
Thanks.
Chris_Messina
I believe you would need to “Open Frame in New Tab” and then run the Web Clipper extension on that new Frame. The parent of the frame can’t access a frame’s DOM via CSS.
Thanks, Chris.
Our organization is wedded to Chrome and it doesn’t have the open frame in new tab function anymore. I did try it in Firefox for kicks (which still has that feature) but just ended up with a mostly empty page.
This Chrome extension might help. (Haven’t tested it, just did a quick search and found it).
