How would you design the base, tabs in Airtable to manage multiple forms, based on Product Records and their submissions
Topic Labels: Base design
614 0
Raihan_Kabir
Hi everyone,
Can you help me understand what is the proper way to design base, tabs that are maintenance-friendly?
So I have a Product table/tab on Airtable. From each product item, I want to create multiple forms based on type e.g. Type-A, Type-B, and then record the form submissions so that it’s easy to manage the submissions.
Thanks in advance.
Regards,
Raihan Kabir
0 Replies 0
