I cannot connect on wifi but it works when sharing connection with iphone
825 2
Matthieu_Valle
Hi there :wave:
I have a strage problem, and my title speaks for itself : In cannot connect on wifi but it works when sharing connection with iphone.
Does anyone know why ?
Thanks to you all for your help !
Matthieu
aru_kun
One of our customer is facing the same issue.
It seems to be related to internet provider (Orange). To be more precise, there is a routing issue on their side.
Marc
Orange is indeed my provider. Hope it will be fixed soon :cry:
Le mer. 2 oct. 2019 à 12:04, aru_kun via Airtable Community Forum airtable@discoursemail.com a écrit :
