I need help with a linked fields problem
1525 10
Jose_C
Hi all,
I have a problem with a project i am carrying out.
I have a table A. with a X record which is linked to a field Y in table B and field Z in table C.
After I have a table D. This records are linked to a field in table A.
So , records in table D , are linked indirectly to table B and C.
Now i have a table E, which is an input record to control hours.
When I add a record with a field linked to table D, I can add a field with a lookup function, to show the linked field in table A.
My problem is that i need to fill automatically as well, fields Y and Z which are linked to field in table A.
Some idea how to perform this task?
Many thanks in advance
The trigger is incorrect. It should be “When Record Matches Condition” and the condition should be 1 is not empty and 5 is empty
10 Replies 10
Hi @Jose_C
You can do that by getting the Record Id from Table B & C to Table A, then using those record IDs trigger an automation to update those records based on data from Table E
Hi @Mohamed_Swellam
Many thanks for your help, but i can´t do it work with your approach.
I am going to be more explicit in order to receive your help.
I select from [1]. a linked field, lets say HU-3/PRD43-1
Automatically with a lookup i get [2] and [3] and [4]
This field [4]. needs to be “copied” in another linked field i [5] in the same record
Thats the point… i am trying what you say
but , im stucked.
Nothing works.
If you can give me a solution, I will be very grateful
This is very easy actually :slightly_smiling_face:
You just need to input the correct values in the above fields.
Record ID is the Record ID from the test step and the field you need to update “Prefil comprador” should have a dynamic value of “Pais name”
I made a mistake
[5] is pais
but then i try this
and then I input [1] that automatically puts [4]
but not [5]
it is still empty…
automation is not working, and i dont know why
:frowning:
Jose_C
Many thanks,
it works like a charm!!!
Jose_C
The only problem is that changes in [1]. as it is a linked record from other table, is not reflecting in [5]
it is like [5] is static after the automation.
Some idea?
You mean that 5 can change? In this case we need to think of another trigger. Maybe when a field is modified and make it watch 1?
Jose_C
It not very usual, so i am going to remain with your solution.
Many thanks
