Hi
I am setting up an Integtomat scenario to backup Airtable bases with Webhook and using Airtable API.
I am using blobjson to create and make a call.
I keep getting a syntax error. What is the correct syntax for JSON?
I have an HTTP module in my scenario, bug I don’t know what endpoint fo I use on the HTTP app.
I have two linked tables, so do I use “Retrieve Records” or “Create Records” in Airtable API?
Thank you,
Mary
I can post more info., I sent just going out.
Thank you!
