I need some help regarding "Scripting Extension"
828 2
SalDevTech_Comp
Hi, I’m newbe at using “Scripting Extension” and I had an issue with using this extension. Let’s jump to the point. Here I have 1 table that I make as “Student Attendance”. in that table I have a grid view and calendar, so what I am trying to do is connect the grid view with the calendar.
So for example:
in the grid view section, I have these (Field/Column) “Name, Start Date, End Date and Select days in a week.”
Screenshot (5)
So the problem I can’t solve is I can’t find a way to show already selected days in grid view to the calendar. I want it like auto-generate date in calendar by “selected days in a week”
HI @SalDevTech_Company,
I am unsure where the scripting app is needed here.
The Grid view and Calendar view are views of the same data, just laid out a little differently.
In your Calendar view you want to show each person name on a date for the days of the week they have attended? For example Alex will show on 9/18, 9/24, 9/25, 10/1, 10/2…
Are you looking to have the scripting app find the days of the week between the range of days?
Hi, thanks for your response, in a short time I have changed my mind I saw a weakness in the airtable calendar that’s why I decided to use google calendar and I’m glad I can connect it via “automation” but there is one thing/function that is not available
i.e. (Custom recurrence) which is on google calendar.
So is there a way to set (Custom recurrence) from airtable?
