If / And / Find Formula Help
601 1
Matt_Jensen
I need to generate a lead time result based on the contents of a product description {Item Name}. Any help here would be much appreciated.
If find “Spider” in {Item Name} result = 30
If find “Raw” in {Item Name} result = 3
If do NOT find “Raw” or “Spider” in {Item Name} result = 7
I tried the formula below, using all the colors in the descriptions to try to isolate the result, but it sums up the results. ie. “730”.
IF(FIND(“Raw”, {Item Name}), 3) & IF(FIND(“Black”, {Item Name}), 7) & IF(FIND(“White”, {Item Name}), 7) & IF(FIND(“Clear”, {Item Name}), 7) & IF(FIND(“Turquoise”, {Item Name}), 7) & IF(FIND(“Spider”, {Item Name}), 30)
Chris-T
Hi Matt. Give this a try…
IF(FIND(‘Spider’,{Item Name}),30,IF(FIND(‘Raw’,{Item Name}),3,7))
Good luck.
