I’m new to formulas, loving it but struggling a bit as well…
I’m trying to automate a change in my records, from a phase of the process to the next, at a specific date using IF/AND.
I created a fromnow field called “Calculation” and when it gets to 0 days, I would like to change my Phase en cours to the next phase. It looks like this :
It’s unfortunately not working and I can’t figure out why (it says “Sorry, there was a problem creating this field. Invalid formula. Please check your formula text.”)
Most of it looks fine, but toward the end of your formula, you have this:
"Coaching terminé",
There should not be a comma after that string unless you’re providing the third argument for the IF() function. Remove that comma, and it should work.
That said, there’s a lot that could be optimized with this. First off, because {Calculation} = "0 days" is a part of every condition, do that once in an outer-level IF() function, then only check the {Phase en cours} field in the inner tests. No need to use AND() every time.
On top of that, because you’re just switching the output based on what’s in that {Phase en cours} field, you could further optimize that central portion with the SWITCH() function.
