IF & AND statement on two fields, date and checkbox
614 2
Douglas_Roberts
Hi
I have two fields that I am trying to use an IF AND statement on
One is a date field {Rollout Date} and one is a checkbox {BU Code Updated}
I want to write a statement that returns an “error” message when the date is before today’s date and the checkbox is {BU Code Updated} checkbox is unchecked - nothing needs to be returned if the date is after today and the checkbox is unchecked
Raminder_Singh
7 - App Architect
7 - App Architect
This should work: IF(AND(IS_BEFORE({Rollout Date}, TODAY()), NOT({BU Code Updated})), ERROR("Your error here"))
Raminder_Singh
7 - App Architect
7 - App Architect
Thanks. worked perfectly
